deactivate voicemail
Bear11
Hi, I need to deactivate voicemail. Tried calling the help desk but they did not understand the question never mind how to achieve it.
Reading the forums it seems that requests are picked up from here & actioned - Hope thats true.
7 REPLIES 7
198kHz
Fixes: 42
Re: deactivate voicemail
Welcome to the forum. 🙂
It's true, but might take a day or two, and of course it's the weekend just now.
Meanwhile, you should be able to do it yourself by logging into the Member Centre and heading to:
https://www.plus.net/member-centre/phone/call-features
BT technician (Retired)
Fixes: 1,664
Hi there!
I'm really sorry for the issues you've had to deactivate voicemail.
I've arranged this and it'll be removed within 24 hours. For future ref, you can do that via the link which @198kHz provided.
Let me know if there's anything else you'd need help with.
Bear11
Yes that's what the site implies but it does not work.
The page autofills a tick in the box no matter what you do - CS have to deactivate
Bear11
Many thanks
Fixes: 1,664
Ah that's really odd. What web browser are you using and did you try a different browser?
DennisB33
Hi, I'm having the same problem, I can't deactivate the voicemail option, it keeps switching itself back on.
The box is unchecked but underneath it says "Currently active".
Any suggestions?
Thanks very much
MatthewWheeler
Fixes: 503
Hi @DennisB33
I'm sorry to hear you've had issues removing voicemail from your line.
I've sorted this out for you now and it should be gone in the next hour or so
Let me know if it isn't
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
