caller display not working.
WendyG1
caller display not working on either of phones. even though it says its active on my account. did the steps ive found on here and it still don't work. anyone  know how to get it working. thanks
6 REPLIES 6
Fixes: 387
Re: caller display not working.
@WendyG1 Welcome to the forums. Is this a new Plusnet account, and has caller display worked previously?
WendyG1
yes new plusnet account been with them just over a week and a bit now. yea was with bt before and it worked fine with them.
Fixes: 387
OK - sounds like it hasn't completed on either the PN and/or BT side properly - I would give Plusnet CS a ring and ask them to check.
csmith94
Fixes: 31
Thanks for getting in touch @WendyG1, I'm sorry about the hassle with Caller Display not being added. I've done this for you now and it wasn't added on the line, normally it only takes a couple of hours to activate but I'd give it up to 24 hours. After this if you still notice it's not working, just let us know on this thread Smiley
 Curtis Smith
WendyG1
thank you both its all working now. thanks again much appreciated.
WendyG1
thanks for your help it was much appreciated.
