answer 1571
- Home Phone
- answer 1571
answer 1571
02-07-2014 10:41 AM
I don't have this active on my line, yet twice it has taken a message. I have check on both occasions and it is definitely unchecked. Has anyone else had this - I have raised a ticket with Plusnet. I find it much better to use my own answer machine.
Message 1 of 2
(731 Views)
1 REPLY 1
Re: answer 1571
02-07-2014 10:45 AM
Hi AlanAtHome,
Sorry to hear you've had issues issues with this. I'll take a look through the supplier systems to make sure you haven't got this service enabled on their back end, it certainly seems to be removed on our side but I suspect the problem sits on the supplier side!
I'll drop a support ticket on your account with details of the findings and outcome for you
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
Message 2 of 2
(290 Views)
