Voicemail
- Home Phone
- Voicemail
Voicemail
29-01-2016 10:51 PM
My features page says it is turned off but at the moment 1571 works.
How do I get it turned off again if it is showing as off already.
Also I am now getting a lot of calls where Caller ID is not working. I know it is not working as they are calls from family mobiles.
Has something been changed?
Re: Voicemail
05-02-2016 12:45 PM
I've placed an order to remove voicemail and sent an email to query why this was added back on in the first place.
In regards to caller display when you say it's not working on 'a lot of calls' are you still getting calls come through where this does work?
Re: Voicemail
05-02-2016 2:25 PM
I have been keeping a watch on Caller Id and it seems to fail when the caller is on a mobile.
It used to work fine.
Re: Voicemail
05-02-2016 2:31 PM
Re: Voicemail
05-02-2016 2:56 PM
Re: Voicemail
05-02-2016 3:29 PM
Re: Voicemail
15-02-2016 8:44 AM
If you could PM me, I'll let you have his customer name.
Re: Voicemail
15-02-2016 9:03 AM
Re: Voicemail
19-02-2016 12:52 PM
I WANT TO TURN OFF MY 1571 VOICEMAIL .
Re: Voicemail
19-02-2016 3:22 PM
My colleague has responded to your duplicate post on this here: http://community.plus.net/forum/index.php/topic,148075.msg1308117.html#msg1308117
