Voicemail extra
Pondo
Voicemail extra
I applied for voicemail extra approximately six weeks ago and still waiting for this to be applied. Does anyone else have the same problem?
2 REPLIES 2
Fixes: 383
Re: Voicemail extra
@Pondo Have you contacted Plusnet to question the delay?
adamwalker
Fixes: 223
Re: Voicemail extra
Hi there Pondo, I've just checked and voicemail should be active on your line. Can you let me know what happens when you try to access messages?
 Adam Walker
