Unable to set up call divert
IngeJones
I have activated call divert on my account - it shows green in the Home Phone Control Panel
However, when I try to set up call divert using * 21 *, I immediately hear "Sorry, the service requested is not available. Thank you for calling, please hang up".
Where to go with this please?
5 REPLIES 5
SammyM
Fixes: 101
Re: Unable to set up call divert
Hiya @IngeJones,
I'm sorry you are having this issue and I can appreciate what an  frustration this can be.
When we add it to the line there is no setup needed, does the handset have a built in answer machine?
 Sammy M - Sheffield Team
IngeJones
No, it's a plain cheap phone.  I was trying to use *21* to divert all calls to my mobile as we don't use the landline phone at all.
SammyM
Fixes: 101
Ah ok, I completely misread your post there @IngeJones Sad
Sorry about that, I have fixed this for you and it will be available to setup in 1 working days.
IngeJones
Thank you, it's working now Smiley
Fixes: 241
Just to be sure: are you aware that you will be charged the cost of calls diverted to your mobile?  If you receive such calls and have a call plan, make sure that such calls do not last more than the "free call duration".
If you do not have a call plan, note that calls diverted to a mobile might still incur a charge, even if not answered - some mobile operators initiate "call connected" (and thus chargeable) as soon as the call enters their network.
Callers to your landline number will be charged even if the diverted call is not answered as the diversion is deemed to "answer" the original call.  See https://community.plus.net/t5/Home-Phone/Why-do-we-have-to-pay-for-unanswered-phone-calls/m-p/101141...
