Unable to make ANY outgoing calls on my phone line
nicholsfamily81
I moved from Vodafone to Plusnet this Tuesday. By 12pm the internet had been migrated from Vodafone over to Plusnet which was fine. However since the witch over I am no longer able to make ANY outgoing calls. I get a pre recorded message when I try calling either a known working mobile number of a known working landline number saying "Sorry you are barred from calling this number" This is a new account so I am not in arrears. Openreach have been out and spent two hours on site today literally testing everything possible and everything has come back fine. No one hat Plusnet is able to tell me why this is happening which is super frustrating. Can an admin please help resolve this issue. Plusnet are saying there are no bars on the line yet when I try calling any number nothing works apart from 17070
4 REPLIES 4
Legend
Fixes: 254
Re: Unable to make ANY outgoing calls on my phone line
@nicholsfamily81 Welcome to the forums. I am not PN staff, but when you dial 17070, does it correctly identify your number?
MatthewWheeler
Fixes: 479
Sorry to hear that you've been having issues @nicholsfamily81
I can see we've investigated this at length and we haven't found any cause for this yet.
I'm looking into this further and we'll update you as soon as we know more
[internal]
Upon further investigation, it appears you have a third party product known as CPS on your line which we don't support. I've asked our suppliers to remove this for you and this can take a couple of working days but in the meantime, if you add 1280 to the beginning of the number your dialling you should be able to dial out,
 Matthew Wheeler
nicholsfamily81
Matthew
Thank you I’ve tried dialling 1280 and then the number and it works 😊
Regards
Toby Nichols
MatthewWheeler
Fixes: 479
Glad to hear that's worked.
It's something you can use in the interim until CPS has been removed.
We'll update you once that's been done
 Matthew Wheeler
