Strange Voice Mails
- Home Phone
- Strange Voice Mails
Strange Voice Mails
27-07-2017 1:02 PM
Hello.
I have a very odd error that's been going on for some months but is now getting worse.
I come in to a voice mail that says
"please redial with the area code 01908 etc etc (it then lists my OWN phone number) and then says "you have not been charged for this call"
What on earth is going on? How am I getting calls resulting in voice mails where the usual automated voice telling you to use an area code is there reading out my own number to me.
At first this would happen once a week, now we are receiving them 3 or 4 times a day. Any suggestions welcome...
Re: Strange Voice Mails
27-07-2017 2:32 PM
That's quite a strange issue. I'm going to try to remove and then re-add your voicemail feature. The process can take an hour or so, I'll let you know once it's completed.
Anoush
27-07-2017 3:56 PM
28-07-2017 12:00 PM
Hi
I am now getting the message attached but on the voice mail base unit of my BT phone. Your forum doesn't allow .wav files to be uploaded so once you download it, change the jpg to wav and you'll be able to play and hear the message.
28-07-2017 12:04 PM
28-07-2017 12:12 PM
Well it's a set of three handsets with one base unit - nothing special and everything else seem fine. We get a lot of calls where they are silent if we answer - if we don't, we then get this message left!
Of note I can't dial locally without the dial code either - is that usual?
28-07-2017 12:13 PM
Also I'm wondering how this is skipping the PlusNet voicemail service entirely and getting to the phone base unit now?
28-07-2017 12:20 PM
Not usual, but that does apply in Milton Keynes area -
http://www.area-codes.org.uk/01908.php
ADSL2+ Billion 8800NL
28-07-2017 12:43 PM
That's odd. It's usually the voicemail service that kicks in before a built-in answering machine on the handset. I guess that the opposite could occur too. You could try removing the voicemail feature here. That way, if the problem still occurs it may point to the handset instead.
28-07-2017 1:07 PM
How would a handset be responsible for generating voice mail messages complaining about a missing area code after receiving an incoming call? The phone rings, I don't answer it, a few seconds later I get the beep to say there is a message and this is what has been left. Something from the outside is generating these messages.
Are you able to see when/where my calls are coming from.
Bonus points if someone can tell me the "calls are coming from inside the house"
28-07-2017 8:04 PM
Very very odd.
Just to clarify - are these messages definitely from 1571 and not from your answering machine?
31-07-2017 10:55 AM
I'm afraid not.
To try and rule out 1571 voicemail, I'd recommend trying what Anoush suggested:
If your handset has built in voicemail and you also have voicemail on your line itself, one will simply be made redundant by the other.
