Reporting a faulty phone line
- Home Phone
- Reporting a faulty phone line
02-03-2016 8:09 PM
Apologies if the answer to this is online, but I've searched and can't find it.
Is there a way of reporting a noisy phone line other than by phoning technical support? All the information appears to suggest that it has to be done by phone.
Many thanks.
Many thanks.
Message 1 of 5
(1,548 Views)
4 REPLIES 4
Re: Reporting a faulty phone line
02-03-2016 8:16 PM
http://www.plus.net/help/?home=helptop
Select phone
Select General Phone Help
Select How to Troubleshoot etc.
Select My line is too quiet or has background noise
Then click on PhoneTroublshooter
Select phone
Message 2 of 5
(750 Views)
02-03-2016 8:25 PM
Oldjim, thanks, I did all that. The fault (crackling on the line) persisted. And the final advice was "give us a quick phone call".
Current waiting time is given as up to thirty minutes and I'm not inclined to use my mobile for that.
Bert
Bert
Message 3 of 5
(750 Views)
02-03-2016 8:34 PM
As you implied "sod that for a game of skittles"
Try this https://www.plus.net/wizard/?p=wizard&page=22945&wizard_id=38
You can of course use the 0800 number which is free on mobiles
Message 4 of 5
(750 Views)
02-03-2016 8:40 PM
Many thanks for that. Report sent.
Bert
Bert
Message 5 of 5
(750 Views)
- Home Phone
