Report 9311706
- Home Phone
- Report 9311706
Report 9311706
18-10-2014 4:11 PM
Re: Report 9311706
19-10-2014 10:26 AM
Re: Report 9311706
22-10-2014 10:18 AM
Bit confused - and since we dont have a phone you cant call us and we cant call you!!
And the Internet connection is very hit and miss. Just have to cross fingers we have a connection when we send - or recieve!
Cheers
Re: Report 9311706
22-10-2014 10:25 AM
Re: Report 9311706
22-10-2014 10:43 AM
Re: Report 9311706
22-10-2014 3:53 PM
Re: Report 9311706
22-10-2014 4:00 PM
I wish I'd seen this before responding to the other thread!
We're glad the phone is working. Normally the broadband connection would also be improved once the phone line is. Looking at the stats on yours, I'm not so sure this will happen. If you could keep an eye on it, it would be helpful. It will be slow for the time being, but this should pick up if the line remains stable.
Tony
Re: Report 9311706
23-10-2014 1:25 PM
Sorry about the double post.
Internet still iffy. Did a speedtest just now and is 179 Down and 344 up (yesterday was 197 Down and 163 Up). Will check again tomorrow. I can use the internet for simple email and google search but no streaming (youtube etc)
Cheers
Re: Report 9311706
23-10-2014 3:16 PM
Thanks for getting back to us to confirm the details on the broadband side of the issue. It sound very much like the phone line fault has kicked what's know as Dynamic Line Management into play on the broadband. This feature reduces the speed of your connection to a level where it can keep the connection going without dropping out, In this instance though, the issue was so severed it appears to have really reduced the speed.
Normally we will start to see this speed increase after the initial 24 hours of the fault being fixed however it is a little concerning that this doesn't appear to have shifted yet. Given this I'll take a quick look over the details of the connection and see where we stand however I would hope that you would see this shift automatically.
Re: Report 9311706
23-10-2014 5:19 PM
Just a quick update for you on this one....
I managed to get the account username from Alex and have a look over the issue for you and this is just as I suspected. I have now placed an order to get the line rate reset so hopefully we should see the speeds return over the course of the next 24 hours.
Please let us know how this looks tomorrow afternoon.
Re: Report 9311706
24-10-2014 2:35 PM
Tested again this afternoon. This time with Ethernet cable connected(not Wireless) and via BT rather than MySpeedTest. Down 0.14Mb Up 0.23Mb.
Tried MySpeedTest but it won't work!! And with these speeds I can't view the PlusNet Youtube help!!
I realise you are trying to help and I appreciate the effort
Cheers
Re: Report 9311706
24-10-2014 4:41 PM
I've just tested the line and can see it's really quite bad still. The SNR hasn't budged meaning you're getting the same slow speeds. I want to just check the details of the reset and I'll update you shortly.
Tony
Re: Report 9311706
24-10-2014 4:52 PM
Your line was still banded which I've sorted it (line tests show you are now syncing at 2Mbit) but I want to keep an eye on it.
I've created ticket ticket 93583104 so that I can check the situation when I'm back in the office on Monday.
If you check the speeds after ten minutes, I'm going to reboot your connection remotely for you.
Tony
Re: Report 9311706
24-10-2014 5:29 PM
I am back!!
And thanks to all your colleagues for their work. Your dedication is appreciated.
Now to persuade my sister to change to PN!!
Re: Report 9311706
27-10-2014 9:03 AM
Things look OK now, but please keep an eye on the speeds.
Remember your referral discount when your sister signs up. Details here
Tony
