Re: Turn off Voicemail
charlton1962
I have recieved voicemail which i did not request and do not want but i went on features which is advised but it will not turn off. i have been on since yesturday trying to sort this out
3 REPLIES 3
Anotherone
Champion
Fixes: 21
hello @charlton1962, welcome to the forum. Has the Voicemail gone off now? - it doesn't go off immediately - it normally takes a little while for the order to be processed by the system.
I assume you used the following link https://portal.plus.net/plustalk/index.php?page=wlr_remove_call_features which requires you to login in at the Member Centre/Portal
(Note - your member centre login/password is different (or ought to be for security) from your forum login).
Mav
Fixes: 516
Moderator's note by Mike (Mav)
Topic split
Forum Moderator and Customer
HarryB
Fixes: 256
Welcome to the forums @charlton1962
Looking at your account, I can't see any requests to remove the call feature. If you follow the link posted by @Anotherone you should be able to remove the call feature from your line.
 Harry Beesley
