Phone not working
djcjuk
Fixes: 5
Phone not working
My phone has no dial tone.  When you phone the number it appears to ring but the house phone does not ring.  Broadband speed download has dropped slightly from 74.0mbps to 64.0mbps. Upload speed has dropped from18.0mbps to 6.2mbps.
9 REPLIES 9
Fixes: 380
Re: Phone not working
I would report a PHONE fault via https://www.plus.net/help/report-a-problem/
djcjuk
Fixes: 5
Thanks John. I will wait and see if a Plusnet member answers.  If I don't here anything I will try your link.  My contract is up for renewal and the speeds I am getting are the new speeds for fibre to the cabinet Broadband. Thanks for your quick reply.
Fixes: 380
@djcjuk Help Team response on here is very patchy/slow. If you want a resolution, use the link now.
willcutforth
Fixes: 113
@djcjuk I have found an external fault on the line and I have raised it to Openreach. It will be fixed within the next 72 hours.
 Will Cutforth
Fixes: 380
You would prove me wrong, wouldn't you, @willcutforth😀
willcutforth
Fixes: 113
@jab1 I'm here to wind everyone up! Haha
 Will Cutforth
djcjuk
Fixes: 5
Hi John (Jab1)
I cant believe how quickly they replied. I was going to use your link but I was charging my phone so had not used your link.
You are doing a brilliant job thanks for trying to help.
Fixes: 380
@djcjuk  'I cant believe how quickly they replied.' Neither can I - it usually takes a week or more, by which time, the issue gas been solved by other means.
djcjuk
Fixes: 5
It has taken a week but phone line now working and broadband speeds back to normal. Open reach had to book an appointment but no visit was required as it was an external fault.
