Permanently witheld number
JL63
Hello, I wish to have our landline number permanently withheld rather than prefixing with 1470 each time we make a call. Apparently this can be activated by Plusnet. Thank you.
12 REPLIES 12
Smith7
All Star
Re: Permanently witheld number
Welcome to the Forum,
If you have your number permanently withheld you have to enter 1470 before a number you are calling if the person you are calling does not accept withheld numbers
141 is entered before a number to withhold your number if it is not withheld by your supplier.
You have it the wrong way round
JL63
Thank you for the reply, I got the prefix numbers muddled up but I still require our number to be permanently withheld as it was previously when we first joined Plusnet.  Thank you, John
198kHz
Fixes: 42
Welcome to the forum.  🙂
Should be no problem once a Help Team member spots this topic.
Just remember to specify whether you want the version with, or without, the 1470 override option.
BT technician (Retired)
BD
Fixes: 86
Hi @JL63, thanks for getting in touch. I've raised a ticket on your account regarding getting withheld enabled on your account and the ticket I've updated that requires your attention can be seen here:
https://www.plus.net/wizard/?p=view_question&id=21891195
Feel free to give us a nudge on here once you've updated the ticket and we'll happily get this picked up and progressed further for you.
JL63
Thank you for opening the ticket Ben, as per my email reply to you, please do enable the 141 option. Kind regards, John
JL63
Thank you for your reply. A Plusnet team member has now opened a ticket to withhold our number.  Best wishes, John
BD
Fixes: 86
Hi @JL63, thanks for getting back and confirming. If you could please add a comment onto the ticket on your account confirming this then I can get this in place for you.
If after logging into the member center you paste https://www.plus.net/wizard/?p=view_question&id=21891195 into the address bar or a new tab then it should show the open ticket with an option to add a comment on there. Feel free to give me a nudge on here after doing so.
JL63
All done as requested Ben, thank you once again.
Kind regards
Fixes: 1,660
Hi John, I've picked this up for you and I've placed an order to withhold your number with the override option. This should be working within 24 hours. Let us know if there's anything else you'd need help with.
JL63
Hello, thank you for the speedy action, it is very much appreciated.
Kind regards
JL63
Thank you Gandalf, the line is now working with number withheld again.
Best wishes
Fixes: 1,660
Awesome, no problem John. Smiley
Let me know if there’s anything else you’d need help with. Cheers
