Permanent Call barring on Plusnet
- Home Phone
- Re: Permanent Call barring on Plusnet
- « Previous
- Next »
14-01-2014 5:11 PM
I thought the issue here was that reverse charged calls could still be made? I'm sure that would be an issue on any Openreach provided WLR service.
14-01-2014 5:26 PM
Quote Restrictions
The line itself is installed by Openreach just like a BT line, on our behalf. You cannot normally make any chargable calls, but can call emergency services and freephone numbers from it as well as accepting calls. If we allow you to make chargeable calls, or there are reverse charge calls, or any other charges, we will charge you what OpenReach charge us, plus 20%. Outgoing calls are only enabled for established customers and at our discretion. We supply the line primarily for use with the broadband service and do not provide lines without our broadband service associated with them.
14-01-2014 5:30 PM
14-01-2014 7:36 PM
14-01-2014 8:15 PM
15-01-2014 11:10 AM
Quote from: jelv As a matter of interest, this is what A&A say about their offering:
Quote You cannot normally make any chargable calls, but can call emergency services and freephone numbers from it as well as accepting calls.
Interesting. I wonder if they allow calls via an override provider, too (with whom the tenants could set up their own account).
15-01-2014 4:04 PM
Quote Restrictions
Interesting spot which I had overlooked! That puts A&A out of scope then.
So it may indeed be Openreach that forces the risk of billable reverse charges happening - we can thank OFTEL for this.
An incoming call block (or diversion) that cannot be defeated without a PIN would be acceptable as it will obviously block reverse charge calls, only I am not sure if Openreach currently makes this possible.
If it cannot be done then we've fallen at the last hurdle on this technicality and I'm giving up.
I may supply the tenant with a 3g MiFi to tide them over till their line is installed on their own contract but they won't be able to do much video streaming with this!
15-01-2014 4:27 PM
15-01-2014 5:13 PM
So it seems that ADSL is at a permanent disadvantage compared to pure cable Internet, as it has to tow legacy phone functionality along!
15-01-2014 5:59 PM
16-01-2014 11:57 AM
Quote from: IngeJones Apart from my locked cabinet idea [...]
I wish I'd thought of that.
16-01-2014 1:15 PM
As it is every thing's a compromise and has made me realise that if I offer no broadband to the new tenant, at least there's be able to chose their 'favourite' brand and bundle of TV, phone and broadband.
Anyway, the ingenious workarounds given in this thread go to prove that the need for a no-calls broadband service is quite common.
Now its time for the ISPs that we pay money to to come up with a product offering that matches this need.
17-01-2014 4:14 PM
And a monthly fee option to block outgoing "by Admin control" - it shows how much mark up their is when this feature is retailed.
@Ben maybe you could investigate if those features cover all eventualities, e.g. that the incoming calls bar cannot be defeated via a code.
17-01-2014 4:55 PM
The problem isn't the lack of a useful feature it's the fact that our billing system is set up to remove call barring under certain circumstances.
- « Previous
- Next »
- Home Phone
