Outgoing call barring
Landlady
Do Plusnet offer OCB? I was told today by phone that they do not but I’ve read elsewhere today that they do.
11 REPLIES 11
Thrall
Seasoned Pro
Fixes: 23
Re: Outgoing call barring
Landlady
Thanks.
How ridiculous that the sales team said they don’t. I wonder what they mean by ‘ 341# - This will bar almost all calls from your phone’. I wonder if it allows emergency calls and bars all others? That’s what I want.
Thrall
Seasoned Pro
Fixes: 23
There’s only one sure way to find out. You can always remove a bar if it blocks calls you want to make
Landlady
It would be good if someone from Plusnet could give a definite answer as I’m not going to sign up for a contract if it can’t give me what I need. I’ve got a holiday let and need to block outgoing calls, otherwise phone bills would be unmanageable, but need to allow emergency calls. I’ve got that with the Post Office broadband at the moment but they can’t offer me fast broadband, which Plusnet can.
198kHz
Fixes: 42
@Landlady Welcome to the forum. 🙂
Plusnet will be using the same BT Openreach system as offered to any other ISP to implement call barring.
As will be seen here - https://www.bt.com/static/i/microsite/help_and_tips/faults/troubleshooting/barring.html
Codes:
  1. All Outgoing calls are barred except 999
  2. Outgoing national and international calls are barred
  3. Outgoing international calls are barred
  4. Calls to Operator services are barred
  5. Bars calls to manage your Calling Features
  6. Bars calls to premium rate numbers
    *341# bars all calls except emergency calls.  🙂
BT technician (Retired)
Landlady
Perfect, thank you. Do you know if this option is in place now or is it something that’s going to be implemented soon?
Thrall
Seasoned Pro
Fixes: 23
The option is implemented now so once you’ve signed up (or I believe you can choose the option while signing up) you’ll be able to add on outgoing call barring feature.
Landlady
Thank you so much for your help.
198kHz
Fixes: 42
A misunderstanding of terms, I suspect.
They don't offer OCB, which is Outgoing Calls Barred (permanent).
As per the above posts, they do offer Call Barring, where selective barring is controlled by the customer.
Landlady
When I phoned Plusnet to ask, I didn’t ask for OCB specifically, I asked was it possible to block outgoing calls but allow emergency calls.
198kHz
Fixes: 42
@Landlady In that case you were definitely given wrong information by the agent.
