Number to delete last incoming call number
- Home Phone
- Number to delete last incoming call number
29-07-2008 5:44 PM
Re: Number to delete last incoming call number
29-07-2008 5:56 PM
29-07-2008 6:55 PM
You have to dial 1475 and hang up. The system will phone you back after about 20 seconds. If you answer the call all you'll get is a dial tone - you can hang up. If you then dial 1471 the number will be announced as "you were called today at ..... The caller witheld their number".
29-07-2008 8:11 PM
29-07-2008 8:32 PM
You are still with BT I assume as it won't work if your phone is with PlusNet - corrected - yes it does
29-07-2008 8:37 PM
29-07-2008 8:42 PM
It works just fine with PN - in fact it's one of their free services (1471 erasure) - I've used it a few times and I'm with PN for phone!
@pierre_pierre
I used it so the other half didn't know her cousin had phoned (we were arranging a surprise party) - I also had to erase the number from the recent calls list on the phone.
29-07-2008 8:59 PM
It may be that your exchange doesn't support the service. From Openreach's price list:
"The availability of Calling Features facilities depends upon the exchange type which serves the End User."
29-07-2008 9:03 PM
It worked for me on Plusnet Home Phone as described by Paul03 above.
A lot easier to keep secrets if the caller is trained to dial 141 or withhold their number by whatever means before calling. Even then OH will begin to get suspicious if withheld numbers occur too frequently. Blame salespersons?
29-07-2008 9:32 PM
It has occurred to me that it may not work because I have number withheld.
29-07-2008 9:39 PM
30-07-2008 8:45 AM
Same net result as the method above, but guaranteed to work every time.
Alternatively, dial your home number from a mobile, but don't withold the number - then tell the OH that you called by accident when you knocked/sat on/whatever your phone without the keylock on if you don't want to have a withheld number as the last caller.
30-07-2008 9:28 AM
Unfortunately, my life is not that exciting!
30-07-2008 9:44 AM
- Home Phone
