Noisy phone line
HaresEar
Noisy phone line
Since customer srevice is not available could some one please check my phone line as it has gone very noisy and is also causing multiple broadband drop outs.  Thanks.
6 REPLIES 6
BrightonRock
Fixes: 7
Re: Noisy phone line
Did you run the Phone Troubleshooter? It will do a line check. https://www.plus.net/my-account/tools/phone-troubleshooter/ (You will be asked to log in.)
Don't worry if it says that it has failed as the test can be a bit iffy and may still raise a fault - check in your account for tickets..
HaresEar
Thanks for that. Not sure if it is working or not but it eventually displays a page with
Oops, something seems to have gone wrong
198kHz
Fixes: 39
As @BrightonRock suggests,it may have created a ticket anyway - you can check here:
https://www.plus.net/wizard/?p=search
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
HaresEar
Thanks but no ticket reported.  I'll just have to keep ringing and hope I can through eventually.
198kHz
Fixes: 39
OK, hope you get through. In the meantime, a staff member may well spot this thread and respond.
HaresEar
Thanks for your help. I have raised a ticket myself meanwhile.
