No dial tone
FIXEDTopic Options
- Home Phone
- No dial tone
07-06-2020 9:10 PM
My land line phone suddenly has no dial tone. It was working OK earlier around 3pm. When I call my number from my mobile it says number not recognised. My internet is still working fine though. Please could this be looked at as a matter of urgency as the mobile signal in my rural village is very weak and I can sometimes only get a signal outdoors. My elderly mother relies on my land line to be able to contact me multiple times a day.
Fixed! Go to the fix.
Message 1 of 4
(876 Views)
3 REPLIES 3
Re: No dial tone
07-06-2020 10:27 PM
I've just run the line checker from my account. I take it this will now be resolved without me having to do anything else now?
"We've found a fault with your phone line.
Our engineers will work on the problem you're experiencing. This is usually resolved within 1-3 working days. If this isn't the case, we'll contact you to let you know."
Message 2 of 4
(860 Views)
08-06-2020 4:54 AM
My phone line has suddenly started working again
Message 3 of 4
(836 Views)
Re: No dial tone
08-06-2020 8:32 AM
Hi @Swipe
Sorry to hear about problems with your landline. Good to hear that line is working again. I can see that fault is still with openreach, according to test results - fault is located at exchange. If you will notice that line is not working again, that will most likely mean that engineer is now working to fix it.
You can view this fault ticket here
Message 4 of 4
(815 Views)
