No dial tone
map1984
No dial tone
I've used the check phone line service and plus net say no issues with my line, however the phone itself was saying to check the line. When I pick the phone up there's no dial tone, and if I try to call my land-line from my mobile, the mobile simply hangs up, it doesn't ring or give an engaged tone.
Any advice would be great, thanks
5 REPLIES 5
Fixes: 385
Re: No dial tone
Try removing and re-inserting the phone line into your master socket.
map1984
Re: No dial tone
Thanks for the Advice, John.
I've tried that, and I've gone on to try replacing the cable, and then trying an old spare landline phone and base unit with it, nothing has had any impact, good or bad.
Fixes: 385
Re: No dial tone
I would ring PN, and get them to send an engineer - there is something wrong with your phone circuit if all those steps have not resolved the problem.
map1984
Re: No dial tone
Thanks for your advice
adamwalker
Fixes: 223
Re: No dial tone
Hi @map1984
I can see we've got an engineer visit booked in for Thursday. I hope it all gets sorted there and then and do shout up if you need any help in the meantime.
Adam
 Adam Walker
