Landline
JaneBarr1945
Landline
Does anyone know.
Can i cancel my landline on my broadband account, without having to start a new contract?
Tags (1)
5 REPLIES 5
Fixes: 392
Re: Landline
@JaneBarr1945 If you are currently on FTTC, you will need to ask Plusnet to switch you to SoGEA, but that will start a new contract.
Tags (1)
JaneBarr1945
Re: Landline
Ah ok. Thank you. I don't want to start a new contract unfortunately 😕
Tags (1)
Fixes: 254
Re: Landline
In which case you will need to stick with what you have got.
What is the intent of terminating the telephone service - which is a part of the current contract, be that provided by Plusnet or a third party, for it forms the primary identity and infrastructure over which the broadband service is delivered.
Depending on the intent, there might be ways of moving to another supplier (EE or BT) and avoiding ETCs, but any change will dictate a new contract.
Tags (1)
mwwagain
Fixes: 4
Re: Landline
@Townman wrote:
........... for it forms the primary identity and infrastructure over which the broadband service is delivered.
Come the removal of POTS then, how will a (formerly) ADSL or FTTC line be identified on the OR side once its' (formerly) associated POTS number has either been deleted or ported to a 3rd party VOIP ?
Tags (1)
Fixes: 254
Re: Landline
Different line identity / configuration ... but that needs a change of the BTW / BTOR 'product / service' and that requires the mentioned change of contract.
Tags (1)
