Landline not Working, Broadband OK
GeoffCheadle56
Not had a working landline since Friday 26th, but broadband is fine. Tried plugging just the phone into the master socket, but nothing there either.
Reported the fault via text to the Plusnet diagnostic bot which initially said it couldn't find any problem with my line, but then said it would do further tests & get back to me within 15mins.
That was at 9.33 this morning & it's now almost 15.33 with no further contact, so what do I have to do now ?
Tags (1)
3 REPLIES 3
Gel
Champion
Fixes: 29
Re: Landline not Working, Broadband OK
willcutforth
Fixes: 113
@GeoffCheadle56 I can see it has now been raised for you. Do you need me to do anything else whilst I am here?
 Will Cutforth
Tags (1)
GeoffCheadle56
Thanks for getting in touch, but the situation is now being dealt with, Geoff
Tags (1)
