I "cannot change your Home Phone product at the moment" ?
Pauly9
Hi,  I don't seem to be able to change telephone call plan:
There's something we should mention...
You cannot change your Home Phone product at the moment.
(I was trying to decide if to stay with plusnet and do line rental saver, with daytime calls. Not decided yet -but it seems I can't change anything anyway?)
Regards Paul
15 REPLIES 15
Fixes: 1,601
Re: You cannot change your Home Phone product at the moment.
Hi Paul,
Sorry for the issues with renewing. I believe I've identified the problem and I'm in the process of fixing it.
It won't be fixed today though but it should be tomorrow, I'll let you know once it has been.
Pauly9
I'm not trying to renew.  Please do not renew anything.  I was trying to change call plan before deciding whether to do line rental saver or switch to another supplier. All I ever get is error messages. Now I get:
Your Home Phone order is currently being processed.
We will keep you updated by email and tell you once your service is ready to use.
Do not renew anything.
Fixes: 1,601
As per my previous response I'm fixing the problem, I'm not renewing your contract.
Fixes: 1,601
@Pauly9 I've fixed the issue for you now, but not without a small complication though. I've added a bit more detail onto a support ticket via your account you can view and respond to by going Here.
Pauly9
It's fixed, as far as I can tell.
Pauly9
Now we cannot view bills:
Something's gone wrong..
Sorry, there's been a problem, but we're working hard to fix it.
Try refreshing the page, but if that doesn't work please contact us.
I'm trying to see the "...crediting your account with £4 towards your next bill" buy currently see no evidence. I want to make sure plusnet is only charging the £5 evenings and weekends and not £9, albeit you had to make it a £4  credit for technical reasons we didn't understand.
how do I see the bills please?
abails0105
Fixes: 60
Thanks for getting back to us @Pauly9
I can confirm the £4 credit has been applied to the account for the call package and will take affect on your next invoice. Confirmation of this can be seen here. When your next invoice generates, you should be able to see the applied credit
 Alice Baillie
Pauly9
Sorry but it's not correct that "Confirmation of this can be seen here.",
it simply gives:
"There was an error
We were unable to access your ticket information."
(Moreover the credit should also be on last invoice as well as next; we simply wanted to remove the free voicemail from the line, not change the call package - that was done by plusnet for technical reasons. Evenings and weekends is £5/month)
Paul
abails0105
Fixes: 60
Further information has been added to a support ticket here
For reference this has also been emailed over to yourself too so you should be able to view the response through email too
 Alice Baillie
Pauly9
Hi, As I said it is not possible to verify any of this as it only says:
It's all such a mess I just want to verify for myself we're being charged correctly; but there's nothing but error messages.
abails0105
Fixes: 60
Do you get this error message on all different browsers? If you've only tried one browser, could you please try some other browsers and see how you get on
 Alice Baillie
Pauly9
I'm using the latest firefox which works well on all other websites, just not plusnet Billing.
It works fine on other parts of the plusnet site; but cannot view bills, even with all plugins and extensions disabled.
Pauly9
Somebody supposedly fixed this, but I still cannot view bills:
There seems no way to actualy view the bills and verify charges since plusnet messed with the telephone product and changed it from evenings to anytime (which customer didnt want - we were only trying to cancel the free voicemail).
All we want to do is view the bill.  Please How?
Pauly9
Fixed by following suggestion  of 'Thrall' to use ‘private browsing’ / ‘incognito mode’. This is with Firefox 86.0.1.
