Hum on the line
forumtalker
Hum on the line
 A hum  started a few days ago - does it need a  line test  to identify the source?
Regards
6 REPLIES 6
Gel
Aspiring Champion
Fixes: 27
Re: Hum on the line
forumtalker
Re: Hum on the line
Thanks, Gel.
I tried the quiet line number and the hum can be heard.  regards
198kHz
Fixes: 39
Re: Hum on the line
If you have a modern master socket, remove the faceplate and try a (preferably corded) phone in the revealed test socket.
If the hum is still there, report to your landline provider. If clear, you have an internal problem.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
forumtalker
Re: Hum on the line
Thanks Aspiring Hero.  I clumsily clicked the thumbs up by mistake.
I did the test with the main socket and the hum  can still be heard.  I assume someone from Plusnet will pick this up, though they may have a backlog after the Christmas holiday and will have to prioritise  those have loss of service.  Regards
Regards
198kHz
Fixes: 39
Re: Hum on the line
You're welcome. Aspiring Hero is Plusnet's appellation - the forum name is 198kHz.
At present you're described as Dabbler - that will change after a few more posts.
Yes, it's pot luck really.
Best to start the ball rolling with the Phone Troubleshooter -
https://www.plus.net/my-account/tools/phone-troubleshooter/
Good luck...  😉
Mads
Fixes: 79
Re: Hum on the line
Hey @forumtalker,
Thanks for reaching out to us and performing some of those troubleshooting steps.
I've now checked over the service and provided a more detailed response for you here, a copy of the ticket will have been sent to the email address registered with us.
Thanks.
