Error message cannot make any changes
willcutforth
Fixes: 113
Re: Error message cannot make any changes
It seems like it has now been resolved. Are you able to do anything with it now?
 Will Cutforth
meic
Thanks, yes there's no error message now and my call features are active.
vnorval
I am experiencing the same issue.  I made a change over a week ago and since then it's said:
Change already in progress
You are not currently allowed to make a change. There is already a change in progress. Please try again later
Please may you fix it for me.  Many thanks.
Fixes: 377
@vnorval What change did you make? It is possible it hasn't actually completed.
vnorval
I removed voicemail.  Surely it doesn't take 11 days to process 🤔
Fixes: 377
OK. if voicemail is inactive now, the chances are that something has gone astray in the automatic processing of the order. It needs manual intervention by Help Team staff, but this is unlikely to be picked up over the weekend as there is little cover. Hopefully one of the team will pick it up early next week.
Loulipop
I have this too. Basically since we moved house 2.5 years ago!
There’s always some error on our account.
Plusnet, can this be sorted. Life has been crazy so haven’t sorted it til now, but I need to change our payment details, and honestly a new deal would be great 😆
Fixes: 1,661
@vnorval - from what I can see Voicemail and Call Protect are both showing in an awaiting activation status, so I've triggered these to complete, which should remove the error message within an hour or so.
If you'd still like either of these removing afterwards, let me know and I'll arrange.
@Loulipop - I can't see any errors in your account. Could you post a screenshot showing the error?
vnorval
Thank you, all sorted 😊
