Error message cannot make any changes
Deb436
hi have had account for seven months now and I have Account error message saying an error has occurred you cannot make any changes to your account while their is a phone order in progress.Please can someone help.Thank you
23 REPLIES 23
Fixes: 384
Re: Error message cannot make any changes
@Deb436 Do you need to make changes? This is an unwanted feature of the Plusnet accounting system, and will need staff assistance (very thin on the ground) to rectify.
Deb436
Not at the moment I was trying to see if we could get full fibre but I cannot do anything  because of the message
Deb436
Fixes: 384
OK. If you want to see if it is available, put your phone number into this:BT Broadband , and post a screenshot (hiding your phone number) if you need any help deciphering it.
Deb436
Thank you dont know how to do a screen shot but it says FTTP mot available. WLR currently available not in a current priority programme
Fixes: 384
OK , so you can't get FTTP then - a pity.
If you want to know how to do screen shots though, which browser are you using?
Deb436
Thanks but no thanks my learning days are long gone Thank you
Fixes: 384
OK. Depends if you like keeping your brain working. I'm 67, but still learning all the time, especially on here. 😀
Fixes: 1,662
Hi @Deb436,
From what I can see there's pending call features showing in your account which haven't yet been activated. I've placed an order with our suppliers to activate them and you should see the error message go away within an hour.
Let me know if there are any issues.
Deb436
Thank you
karlpeters
HI there, having the same issue, however I've not changed anything for over 12mths. Only discovered it when I logged in to see how long I've got left on my contract & whether or not I can now get full fibre (which I can)
csmith94
Fixes: 31
Hi @karlpeters
I've got that sorted for you now so if you fully log off and back onto the member centre, you'll be all good to go!
 Curtis Smith
karlpeters
Just checked and everything's ok now. Thanks very much for your help.
meic
Hi  @csmith94
I've had the same error message re call features for weeks. Can you please sort it?
meic
willcutforth
Fixes: 113
Hey there @meic I have done part of the fix by adding the features via the back end system. I will check back on Thursday when I am back in.
 Will Cutforth
