Disable 1571 help
Pebs
Disable 1571 help
My phone doesn't support 1571 voicemail. How can I turn off this feature. I've tried online but it's not selected as active on the options, however it si active and I am having people leaving voicemails!!! Unfortunately my phone doesn't tell me so I'm missing messages!
14 REPLIES 14
Fixes: 391
Re: Disable 1571 help
@Pebs I'm a little confused - why doesn't your phone support 1571?
Pebs
My phone doesn't notify me when there are voicemails. I have an answerphone which kicks in normally but when I'm on the phone sometimes people leave messages unbeknown to me...today I travelled an hour for an appointment only to find the appointment had been cancelled last night when they left a voicemail.
I don't want 1571. I've not selected it to be active. I have no idea how to stop it taking voicemails
Fixes: 391
OK, I think i follow you. Unfortunately, it is 18 months since I left PN, but I think, somewhere on your Members Centre, there is the option to add/remove features. If you can't find it, give them a call on 0800 432 0200 - but be prepared for a lengthy wait on hold.
Pebs
Yes I found that. 1571 feature is NOT shown as activated. However it obviously is I'm afraid. Looks like I'll just have to try and phone Plusnet?Huh
Fixes: 391
If it isn't shown as activated, I'm a little surprised it appears to be working 😕 , but yes, I'm afraid you will need to call in.
Pebs
I see others have had the same problem as me in the past...looking at posts from 2018 on this forum. Doesn't look like Plusnet have corrected this in the last 4 years sadly.
Thank you for your help. I'll try calling them
Fixes: 251
See this - https://community.plus.net/t5/Home-Phone/Disable-1571-voicemail/m-p/1540789#M26231
It’s not so much fixing this as there being mismatches between Plusnet’s view of the line’s configuration and BTOR’s.
Fixes: 391
Thanks, @Townman - I wasn't aware of that.
Pebs
Still so frustrating. Thanks anyway
willcutforth
Fixes: 113
Hey there @Pebs I'm here to the rescue. I have created a ticket on https://www.plus.net/wizard/?p=view_question&id=229510123 if you can just reply to it, we will get it sorted for you.
 Will Cutforth
Pebs
Thank you so much. I have added a comment to reply on the wizard
willcutforth
Fixes: 113
All sorted now for you Smiley Should be removed within 30 mins.
 Will Cutforth
Pebs
Thank you
willcutforth
Fixes: 113
You're very welcome. If you need anything else, you know where we are.
 Will Cutforth
