Deactivate voicemail
nippersmum
I prefer an answer phone with a flashing light so I am trying to deactivate the voicemail service on my home phone.
I have tried several times to de-select voicemail on the call features page but it will not 'stick'. Every time I return to it it is selected and currently active.
Please could someone help?
Many thanks
Lesley
3 REPLIES 3
willcutforth
Fixes: 113
Re: Deactivate voicemail
@nippersmum I can remove it for you from my side would you like me to do that?
 Will Cutforth
nippersmum
That would be wonderful - thank you!
willcutforth
Fixes: 113
Awesome, I just need you to reply to this ticket for me and then I will action it for you: https://www.plus.net/wizard/?p=view_question&id=233250428
 Will Cutforth
