Damaged phone line
Mrstauf
Damaged phone line
Hi
Just wondering who to contact to repair a damaged phone line? Plusnet, openreach or can I use independent company?
long story short, we are having some building work done, builder removed phone socket, then plaster came along and boarded over the cable! So I now need a new cable running from junction box on roof to the inside of the house
any advice appreciated
thanks
6 REPLIES 6
Fixes: 383
Re: Damaged phone line
@Mrstauf You will have to go via Plusnet.
Mustrum
Fixes: 81
Just to add to @jab1 's post - you "should" go via Plusnet - but if you know a good independent chap it may be worth considering.
198kHz
Fixes: 42
@jab1
Not necessarily - Plusnet will pass to "their supplier" aka Openreach to do the work, and charge handsomely.
In most areas there are ads in the local press and freebie mags from people (often ex BT) who will do the job for probably less than half the price. It's a pretty basic task, and Openreach will be none the wiser, and unlikely to care anyway.
BT technician (Retired)
Fixes: 383
@Mustrum , @198kHz  Thanks for your more knowledgable replies. I really must stop posting answers when my brain is on other thoughts, late at night 😉 . I was quoting the 'official' line though.😀
Gel
Champion
Fixes: 29
adam945
Fixes: 113
Thanks a lot for your time on the phone today @Mrstauf
Following our call, I've just created an open fault Ticket on the account which we'd need you to respond to. Give me a nudge once you've responded to it and I'll be happy to follow up.
You can view the open Ticket here.
 Adam
 Plusnet Help Team - Leeds
