Constant engaged tone
MayK
My phone is not giving a dial tone, constantly engaged. My son has tried putting filter directly in master socket but makes no difference.
Could a line test be done.
1 REPLY 1
Fixes: 387
Re: Constant engaged tone
@MayK Are you sure it isn't a voicemail tone? If you are, report a phone fault via: https://www.plus.net/help/report-a-problem/phone/
