Caller id not working
jgl22
Hi there, the past couple of days our caller id has not been working. The phone just displays external call. Is there anything i can do to get this working again?
I have dialled the *#234# number and it says it is enabled.
I have also tried a different wired phone directly into master socket and it does not work on that phone either.
Any help would be appreciated.
Cheers
12 REPLIES 12
James30
Fixes: 32
Re: Caller id not working
@jgl22  - It's active at our end and the backend system too. To see if we're dealing with crossed line issues can you dial 17070 and check the number it reads out is correct?
James - Plusnet Sheffield
jgl22
Just to update as of today our phone line now does not work at all.
Our internet is also playing up and keeps going down.
Any help would be appreciated as my daughter works from home.
MatthewWheeler
Fixes: 498
Evening @jgl22
I'm really sorry to hear that's happened.
After testing the line I can see a fault known as a loop condition which can be an internal issue with the way things are setup.
Are you able to try another phone at all or the phone on its own with the router unplugged?
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
jgl22
Hi yes i have tried another phone and it displays no line on the screen. This was plugged directly into the openreach mk4 master socket
jgl22
I have also tried with the faceplate removed (just to rule that out) and the phone via a different filter directly into socket and still no line. Im assuming i have to report this as a fault?
jgl22
The router was also unplugged.
MatthewWheeler
Fixes: 498
Thanks for confirming @jgl22
We'll need to book an engineer to get this sorted.
Can you respond to the text I've sent?
 Matthew Wheeler
jgl22
Ah Matthew sorry i missed your message. I did report the fault hopefully i havent confused things
jgl22
I will reply to text now
jgl22
@MatthewWheeler  I have now replied to text. Cheers
MatthewWheeler
Fixes: 498
Thanks for responding @jgl22
I've booked that in now and sent a confirmation via e-mail.
Let us know how you get on
 Matthew Wheeler
jgl22
Will do. Thanks for your help.
