Can’t add or remove call features
Lindab
Hi, for weeks now I have had “awaiting activation “ on voice and Call protect. Please could you help with deleting this as I haven’t ordered or changed anything! Many Thanks
Tags (1)
4 REPLIES 4
Fixes: 382
Re: Can’t add or remove call features
If they are working, @Lindab , give Customer Support a ring on 0330 123 9123 and ask them to do a manual clean-up.
Tags (1)
Lindab
Thanks very much John for replying. I will give them a ring
Tags (1)
willcutforth
Fixes: 113
@Lindab Did you manage to get this sorted? If not, please pop me a private message and I will sort it for you Smiley
 Will Cutforth
Tags (1)
Lindab
Hi Will, I’ve PM’d you.😀 Many thanks
Tags (1)
