Caller ID not working
ClaudiaG23
Fixes: 25
Re: Caller ID not working
I'll need to wait for the engineer's report first but this shouldn't be a problem. I'll check in again in a couple of hours and I'll see what the engineer has had to say.
 Claudia Garner
acsimpson17
Thank You
RealAleMadrid
Fixes: 68
@acsimpson17  A high resistance fault is a line fault so nothing to do with the router so no point changing it. Also the Caller ID problem is nothing to do with the router. It seems the engineer did nothing to fix the fault. You seem to have had a clueless engineer, I would ask Plusnet to send someone who has the knowledge to fix the problem.☹️
acsimpson17
The engineer has also isolated a fault which causes the Internet to drop when the phone is used. His suggestion to replace the router is due to this with the hope that caller id may be affected too. It will be in his report.
Fixes: 387
I agree with @RealAleMadrid - your engineer was a muppet - nothing in you post above his makes any logical sense.
MatthewWheeler
Fixes: 503
Hi @acsimpson17
As others have advised this isn't likely to be the cause but so we can escalate with Openreach can you unplug the router and then call the landline to see if the number is shown or not?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
acsimpson17
Hiya Matthew.
I have disconnected the router from the power and the telephone socket and caller ID is still not working. Still just says incoming call.
MatthewWheeler
Fixes: 503
Thanks for that @acsimpson17
I've passed this back to Openreach and escalated this further.
As soon as we know more we'll be in touch
adamwalker
Fixes: 223
The previous fault report has been closed but doesn't seem to be resolved so I've opened a new one referencing the previous issues and I'll get back to you in the next few days as soon as we have an update.
 Adam Walker
adamwalker
Fixes: 223
Hi there, the fault has been passed back to us asking us to book an appointment, rather than arrange that again I'm going to query this and see if there's anything else we can do to help.
 I'll make sure I get back to you with another update tomorrow and cheers for your patience with this.
 Adam Walker
adamwalker
Fixes: 223
Thanks for your patience, I've reviewed this case with Openreach and with a colleague and we've found another way to get this resolved for you.
We've found even though this isn't a broadband issue, a test on the connection shows up a "high resistance cable fault" this doesn't show on line tests for the phone service.
This will be causing the problem with caller display so to deal with this we're cancelling the landline fault, once that's gone through the systems (on Monday) I'll raise a broadband fault and will let you know what the next steps are.
 Adam Walker
adamwalker
Fixes: 223
Hi there, I should be able to book an engineer now to deal with the cable fault.
Can you pop me an update on your ticket with your availability please? https://www.plus.net/wizard/?p=view_question&id=233236784
We can book those visits in the usual time slots:
AM = 08:00 to 13:00
PM = 13:00 to 18:00
Adam
 Adam Walker
adamwalker
Fixes: 223
@acsimpson17 I'm just letting you know I've closed the ticket just to take it off my "radar" for now as I've not heard back from you.
Please do get back in touch if you still need help with this and we'll pick things back up where we left off.
 Adam Walker
acsimpson17
Hi Adam.
Please keep this open as we do need it to be resolved.
So the next step is for another openreach engineer to visit? Do they have a specific plan this time?
James30
Fixes: 32
@acsimpson17 - They will need to go out to resolve the issue of high resistance imbalance so there won't really be a mention of caller display but as said before a fault with the line being detected on the broadband test is enough to prevent the caller ID data reaching the phone properly causing that issue. Have you got a date in mind for the visit? They do Monday to Friday 8AM and 1PM or 1PM - 6PM.
James - Plusnet Sheffield
