phone number not reconized
rehtnap2023
hi
 when i try to ring a certain number on my landline it comes up as number not reconized. the number is good my mobile and other peopl in the family ring it and its ok its just my landline that doesnt reconize it. its not the hand set ive changed that.
 any ideas
4 REPLIES 4
willcutforth
Fixes: 113
Re: phone number not reconized
Hey there @rehtnap2023 sorry to hear that. Is it a premium number do you know?
 Will Cutforth
rehtnap2023
hi
 no its just a normal landline number
Fixes: 579
@rehtnap2023 do you know if the number has recently been transferred from one ISP to another ?
ukbobboy
Hi @rehtnap2023
Just a silly question, is it possible that your landline may have been blocked, either accidentally or on purpose, by the number you are calling?
UK Bob
