Caller Display not working
- Home Phone
- Caller Display not working
Re: Caller Display not working
18-03-2013 7:16 AM
It seems the maiin cause of intermittend CLID equipment on the line interfering with the CLID signal (from what I've read).
Maybe try a new microfilter (if you're on ADSL) plugged directly into the master test socket with no other equipment on your line other than your modem and Gigaset phone.
If you're still within your 10 day line training period, maybe hold off until this has completed before testing.
If your phone network is reporting CLID enabled then it could well be something within your house that is causing the issues.
18-03-2013 8:51 AM
Quote from: picbits Are you on FTTC or ADSL2 ?
Exchanged is ADSL Enabled
Not within any training Period.
Microfilter working
Thanks any way
18-03-2013 10:26 AM
21-03-2013 11:01 AM
Whatever BT have done at the exchange, Caller display now appears to be working correctly
dick:quote
22-03-2013 5:24 PM
Quote from: Anotherone Do all your Microfilters look like this?
Nothing to do with microfilters, something there end at the exchange
22-03-2013 5:51 PM
02-10-2013 10:12 AM
If you dial *#001# it will tell you what services you have activated on your line. Mine said I had call divert (although the call divert wasn't actually active or ordered). This message appears to also be read out when you have the answer service active. I've been into my account and deactivated it and the message has now gone to "No services active on your account".
If you dial *#234# it will check to see if you have caller ID enabled. If it replies "Callers Identities will be displayed" and you're not getting the Caller ID on your phone then chances are it's a problem at your end so try different phones / master test socket etc etc.
If you dial *#234# and you get the message "Sorry the service requested is not available, thank you for calling, please hang up" then the chances are there is a gremlin in the BT / Plusnet ordering system and you'll need to have further words with Plusnet on the ticket system.
And the third one applies to me will i need to send a ticket in ???? ( If you dial *#234# and you get the message "Sorry the service requested is not available, thank you for calling, please hang up" )
02-10-2013 10:20 AM
I've taken a look on our suppliers back end systems and can see that Caller Display wasn't enabled. I've placed the order on their systems to have Caller Display sorted for you. This feature should become available to you as of tomorrow morning. I'll add an appropriate refund to your account for the period you're being charged for the service.
Really sorry for the inconvenience caused here.
02-10-2013 10:23 AM
no problem at all and thank you for sorting it out
02-10-2013 10:29 AM
02-10-2013 11:20 AM
02-10-2013 3:37 PM
Just checked all is fine tyvm
30-10-2013 1:46 PM
30-10-2013 1:49 PM
It looks as though the Caller Display feature hasn't activated on our suppliers systems. I have just placed an order for this to be activated, this should complete by around midday tomorrow for you - really sorry about that.
14-11-2013 8:15 AM
