Caller Display not working
- Home Phone
- Re: Caller Display not working
20-04-2024 10:06 AM
Was working fine. Dialling *#234# gives "service unavailable".
Tried toggling the service off and on but now stuck in a vacuum ...
An error has occurred
You cannot make any changes to your account while there is a phone order in progress.
Tried to use "support" chat, but completely broken ... every request just refers you back to the website!
Would be very grateful if a human could investigate and re-enable if its at the back end somewhere ...
Many thanks!
Message 1 of 2
(741 Views)
1 REPLY 1
20-04-2024 3:19 PM
Hi @harrishq, thanks for getting in touch. I've re-added caller display as it looks to have been removed, it should now be active so if you give it a re-try you'll be able to use the service.
Message 2 of 2
(710 Views)
- Home Phone
