Call protect 1572 issue.
Wolfieboy
Hi I have come over from BT where I could add the last number to my blocked numbers. Is it the same here on Plusnet?
I have Call Protect enabled in my account but when I ring 1572 it says "This service cannot be connected".
Who can help?
Tags (3)
4 REPLIES 4
BrightonRock
Fixes: 8
Re: Call protect 1572 issue.
@Wolfieboy
I do wonder if 1572 really has been activated on your line.  If it has, then the attached may be useful. Certainly you should be able to block the last number. But the system is less good than that you had with BT.
Tags (1)
Wolfieboy
It certainly has, as I said. It's ticked in the box on control panel.
Tags (1)
BrightonRock
Fixes: 8
I wondered if 1572 was active because of the message that you are reporting.
I would be inclined to ring PlusNet, if you can, and see what they have to say.
It can happen - I don't know how - that the PlusNet system reports a function as active but it isn't on the Openreach systems. The usual first step seems to be to uninstall and then reinstall. I don't know whether you could do that using the control panel; I do know that, if you ring them, the PlusNet team can do it. That would also check whether your problem is caused by some other issue affecting the service.
Tags (1)
MatthewWheeler
Fixes: 503
Hi @Wolfieboy
I'll send you a PM shortly so we can look into this for you
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Tags (1)
