Blocking spam calls
BudsHouse
Blocking spam calls
I have Call Protect and Call Barring set up but I still get some spam calls. How do I block these? 1572 says 'service cannot be connected'
Thanks!
4 REPLIES 4
Fixes: 480
Re: Blocking spam calls
@BudsHouse
Forget 'Call Protect', it will never catch them all. Buy a phone with a built in BT TrueCall call guardian feature. These work in a totally different way by stopping automatic call diallers getting through. I have not received an unwanted call for years.
BudsHouse
Thanks but we rarely use the home phone, so it's not worth it. I hoped there was an easy way to block nuisance callers.
RobPN
Fixes: 15
@BudsHouse wrote:
... we rarely use the home phone, so it's not worth it. I hoped there was an easy way to block nuisance callers.
@BudsHouse
If you rarely use the phone and don't want to spend money on a call-blocking device, the easiest way to stop all those unwanted calls is to unplug your phone.
198kHz
Fixes: 42
Which would suggest that Call Protect is not actually in operation.
BT technician (Retired)
