Are Calls Via 08081703703 Free From Plusnet Charges?
ronroam1
After news of BT's latest price hike I've decided to change provider. I currently use 18185 for most calls and althought BT don't make additional charges I understand that Plusnet do charge. However, after talking to Customer Service it is still not clear if the alternative re-direct number to 18185 which is 08081703703 is charged or not by Plusnet.
Can anyone clarify please? Thanks!
20 REPLIES 20
BenTrimble
Re: Are Calls Via 08081703703 Free From Plusnet Charges?
Hi, all 0808 numbers are free on our call packages.
ronroam1
Thanks Ben, If there are no charges at all then, based on this, I will change to Plusnet. Many thanks!
BenTrimble
No problem, glad to have you on board Smiley
HairyMcbiker
All Star
Fixes: 21
I occasionally use 18185 and haven't been charged for any calls using it.
ronroam1
That's interesting.Customer Service told me the charges that 18185 attracted and they are the highest of the non-inclusive charges. I'll give it a try when I transfer.Cheers.
BenTrimble
It appears that we don't get the information when a customer calls 18185 - which I suppose makes sense, consider this is a carrier pre-select number. In effect, we never even know you make the call.
ronroam1
Thanks for the info. Ben.
Must say that I am confused ; I spoke to Chris in Customer Service who read out the PN charges for making a 18185 call and since then I've see a forum post in Moneysaving Expert by a PN customer who said that he was charged by PN for making 18185 calls. Yet, later in the thread, another post by a PN customer said that they were not charged.
Your comment that you don't 'see' the 18185 calls is logical as it would still remain a BT line in effect and, as a BT owned re-seller,  then the same rules should apply to PN as they do with BT but there seems to be a lot of contradictory information about.
HairyMcbiker
All Star
Fixes: 21
As I said I don't make many calls via 18185 (or many calls .) but I can't remember ever seeing a charge for 18185 appearing on my pn bill. As Chris said it is cps so should be filtered out before they get it, unless they have started blocking cps?
ronroam1
Well, I've scoured various web sites and there are a lot of conflicting stories but I think we have to rely on Ben's last post (seeing that he is from the right department) that PN don't charge. If I do get a bill for 18185 calls after transferring my line then I won't be a happy bunny...
HairyMcbiker
All Star
Fixes: 21
Simple thing to check make a call and check the on-line logs to see if you have been charged, if they have started charging then they have changed the conditions and I haven't had any notification of it.
nadger
I've been using 18185 for nearly 3 years from my Plusnet land line.
Never had a problem  Smiley
BenTrimble
@ronroam1
Sorry for any confusion, I expect my colleague mis-heard you and thought you were talking about 118185 which could be a directory enquiries number? In any case, I queried our call database for a call to 18185 and we have none whatsoever - we certainly can't charge for it if we don't know you're dialling it!
bewin
Can anyone confirm which phone number is required to be dialled from a Plusnet home phonein order to access the 18185 indirect access phone provider: -
(1) dial 18185 = 5p connection fee + 0p per minute within UK
or
(2) dial 0808 1 703 703 = 5p connection fee + 1p per minute within UK
Additionally, does Plusnet make a charge for using either of the above phone numbers?
spraxyt
Aspiring Legend
Fixes: 75
In the previous post Plusnet said
Quote from: Ben
... I queried our call database for a call to 18185 and we have none whatsoever - we certainly can't charge for it if we don't know you're dialling it!
I think that makes it clear that if you dial 18185 Plusnet won't know about it which means they can't (and don't) make any charge for it. So the cost of calls via 18185 should be whatever that service provider lists in their tariff.
David
