1572 service cannot be connected
JayEs
I hope everyone is well.
I tried calling 1572 to add a spam caller number and it plays a message saying that it cannot be connected. Any help would be very much appreciated, thank you.
9 REPLIES 9
Fixes: 1,661
Re: 1572 service cannot be connected
Hi @JayEs, I've had a look and it doesn't look like 1572 is active on your account. If you go here Call Features | Member Centre | Plusnet you can request it by placing an order for Plusnet Call Protect.
JayEs
Hi @Gandalf thank you so much. I've requested the feature using the link you shared. Will try it out tomorrow and report back, thank you again.
JayEs
Hi @Gandalf I can see that the service is now active when I check online but when I try to use the service, I get the same service cannot be connected message, thanks.
Fixes: 1,661
I've made a change, try again in a couple hours - let us know how it goes.
CMOTD
I'm also getting 'this service cannot be connected' when I dial 1572. Help please.
Marsh
Fixes: 41
Hey @CMOTD 👋
I've looked into this for you and can confirm that 1572 is on your account, but it is not on your line. I have placed an order to correct this, and it should be completed within 24 hours. Please let me know if the issue persists.
Josh
CMOTD
Fixed now  - thanks. Why did it stop working in the first place though?
Marsh
Fixes: 41
Heya @CMOTD
Glad to hear it worked. I have had a look at the orders placed on your account, and I can see our robot placed an order to remove the 1572 feature, and this was triggered by a request made on this ticket
https://portal.plus.net/wizard/?p=view_service_notice&id=668446004
Josh
CMOTD
It seems your robot is not very clever! All I did was change my mobile number not the landline so shouldn’t have affected the 1572 service.
