1571
- Home Phone
- 1571
1571
28-01-2009 8:59 PM
Re: 1571
28-01-2009 9:03 PM
Re: 1571
29-01-2009 9:57 PM
Re: 1571
31-01-2009 4:17 PM
Re: 1571
31-01-2009 4:28 PM
Call features
Free: 141, 1471, 1471 call return, 1471 call erasure
I know that 1571 is free from BT and also don't forget that line rental is a little more expensive with them too, hence 1571 is free with them.
If you take more features through Plusnet it does get cheaper though if that is any consolation.
Re: 1571
31-01-2009 8:06 PM
Re: 1571
02-02-2009 8:06 AM
We have caller display and caller waiting enabled for £1.96 a month. Don't need the latter often but it has proved its worth (49p per month with the call feature bundle) on a few occasions when someone has needed to talk urgently and we've been on the phone at the time.
Unlimited Fibre Extra and Unlimited UK & Mobile Calls
Mac OS12 and Firefox user with latest versions of both
Re: 1571
02-02-2009 5:22 PM
Re: 1571
02-02-2009 5:43 PM
With PlusNet you also gain over BT on the free 'evening' calls as theirs run from 18.00-06.00 whereas PN's are 18.00-08.00
(P.S. We have 2 cordless phones but they're linked up to a base station/answerphone and all 3 show the caller.)
Re: 1571
10-02-2009 10:18 PM
Re: 1571
11-02-2009 6:31 PM
I bought a set of telephones last year with an answerphone and find it much better. Also, I can switch it off if I wish.
Re: 1571
11-02-2009 7:10 PM
Re: 1571
11-02-2009 9:30 PM
Re: 1571
11-02-2009 10:28 PM
Re: 1571
11-02-2009 11:03 PM
Calls which are picked up by someone's voice mail will be "charged" as per your package. If you're on Anytime+, for example, calls picked up by voice mail will be "free" as they're part of your inclusive calls (provided you've dialed an 01,02 or 03 number).
