0042 Numbers getting through with call protect
ep1987
It's my understanding that these are international numbers.
I have turned call divert on for international, withheld and unrecognised.
However numbers beginning 0042 are getting through (different ones each time so no point in using the block last call) at a rate of about one a day.
Is the plusnet recommended list being on overriding my preferences or is the issue something else?
I have recently switched from BT and i received almost no nuisance calls at all in 5+ years while with them using their call protect.
5 REPLIES 5
Fixes: 580
Re: 0042 Numbers getting through with call protect
Country code +42, dialed as 00 42 from many places, is an incomplete code in Europe. +420 is the Czech Republic, +421 is Slovakia, and +423 is Liechtenstein. Other +42X codes may be assigned in the future.
So if the number being presented starts with other than 00420, 00421 or 00423 then I suspect its not being recognised as a valid international number by the Call Protect system. You would perhaps have thought that Call protect would handle these as 'unrecognised'. but I'm afraid not, its definition of unrecognised is 'unavailable' i.e no caller ID
ep1987
The last two were 00424 and 00428 so it appears that they aren't being picked up as international.
Is there any hope of plusnet fixing this?
Fixes: 580
Plusnets Call protect system is basically the BT system, except that it doesn't have the Web interface. The basic functionality is provided directly by BT so I guess there's little chance of it being fixed.
ep1987
I was with BT for 5+ years and never got these calls. Switched to plusnet a couple of weeks ago and the problem started.
198kHz
Fixes: 42
I have an old standalone Audioline CLI display, and occasionally get a (presumably spoofed) UK mobile number displayed, but it also says "International".
Conversely, I've sometimes seen a number starting '00' but without the "International" bit.
I would conclude from this that if an apparently 'international' number is spoofed from within the UK then the Call Protect system would not recognise it as being international.
BT technician (Retired)
