fifa 12
- Gaming
- fifa 12
fifa 12
01-02-2012 11:22 PM
Hi when i play fifa 12 it says my firewall is restrictive how can i fix this please?
3 REPLIES 3
Re: fifa 12
04-02-2012 6:39 PM
Agreed, Me too. So annoying.
I've tried everything, Port forwarding, Static IP, UpNp enabled but still a restrictive firewall. It's strange because the 'patch' for the Thompson router actually Opened the NAT on MW3. I've contacted EA but they are useless at helping saying that different games use different servers etc. etc., and I should turn off my firewall. Plusnet say that the firewall is unable to be changed remotely, but it say's 'This level is protected and not editable.' So I need to turn it off and see if solves the issue. Can't afford a new (decent) router. BUT ITS SO FRUSTRATING, being kicked and losing connection from games that your winning, which counts as a loss.
Please help someone! Is this EA sever rubbish or an issue with plusnet / router?
Cheers!
UPDATE - managed to turn the Firewall off by creating a new 'power user' for the router, BUT the FIFA firewall is still restrictive wtf! Is EA!?
Cheers!
Re: fifa 12
09-02-2012 3:03 PM
set the ps3/xbox to dmz mode on the router.
there should be options in the router page to do this although every brand seems to word it differently.
carefull you dont set all the connections to dmz though.
Re: fifa 12
11-02-2012 4:43 PM
ive give the ps3 a static ip and opened the ports for fifa still no joy.
