advanced warfare lag issues
- Gaming
- advanced warfare lag issues
- « Previous
- 1
- 2
- Next »
Re: advanced warfare lag issues
19-11-2014 7:33 PM
19-11-2014 7:48 PM
19-11-2014 7:50 PM
20-11-2014 7:29 PM
21-11-2014 12:01 AM
24-11-2014 6:11 PM
24-11-2014 9:33 PM
26-11-2014 1:43 PM
just out of interest i port forwarded the correct ports following intrsuctions on port forward . com then used there tool to ping the ports and the results said there closed and un reachable
26-11-2014 1:57 PM
When you opened the ports you should have assigned it to the IP address of the console. Ensure your router assigns a fixed IP to the console else it may assign it a new IP address each time you turn it off and so the portforward rules will not longer to be the correct device.
Maybe try setting up a ping graph like mine at thinkbroadband and see what that shows. Note you can setup a graph with a dynamic ping, it will however need setting up each time you reboot your router though.
Finally if you want to double check good practice see the post here:
http://community.plus.net/forum/index.php/topic,134182.0.html
Hope that helps.
26-11-2014 2:34 PM
26-11-2014 5:51 PM
26-11-2014 7:00 PM
- « Previous
- 1
- 2
- Next »
