Ps4 all games !
wilma1964
Ps4 all games !
Every time i play online day or night i lag and have terrible button lag which makes gaming impossible !! Im on fiber and get 73 down and 16 up ping stays below 10 and jitter of 4 so why every game of fifa on PS4  do i get this problem ? Unup is off tried dmz tried port forward got a vdsl to replace standard router please help as our contract is due to expire and we will go elsewhere !!!
8 REPLIES 8
ghos7em1
Re: Ps4 all games !
what fibre router do you use? if you have qos enabled turn it off.
wilma1964
Re: Ps4 all games !
Im using billion 8800nl and not useing qos
Gledge
Re: Ps4 all games !
Hi I have been having BIG problems with my ps4 and plusnet gear.
This is how i fixed the problem, well sort of!
Unplug your technicolour router and plug your ps4 in to openreach box
After i asked plusnet support staff, can i log on to PSN through the openreach box (not the router), they told me NO!,
***BUT***
I did it anyway
On th PS4,
go to setting, then network, setup new connetion but go through ***PPPoE*** -(plusnet network login)
enter your network login
***(username@plusdsl.net)***
***(password) = the one you use when you phone up your acc.***
then after that set everything to auto and DO NOT USE PROXY, test you connetion.
BANG DONE
Thou this way cuts out your router and everthing connected to it, the only thing conneted to the net is your ps4 and your openreach box...
PSN ID Gledge
I no longer have lag or NAT problems and seems to be much quicker when loading through games.
Mathias
Re: Ps4 all games !
Maybe see here for tips in setting up your router for gaming:
http://community.plus.net/forum/index.php/topic,134182.0.html
I've enabled QoS on my router (Dlink DIR 868L) and it's helped when others are streaming in the house.
ghos7em1
Re: Ps4 all games !
@wilma is your fifa 14 controller settings the same as what ea as stored on there server?
wilma1964
Re: Ps4 all games !
None of the tips helped but much appreciated , as for the controller  it's classic button layout so non edited =[
Chris
Legend
Fixes: 169
Re: Ps4 all games !
@wilma1964
Your line is disconnecting a lot, see my response to your other thread to see this: http://community.plus.net/forum/index.php/topic,134293.msg1174871.html#msg1174871
We should look into this as a fault first of all.
wilma1964
Re: Ps4 all games !
Most of them is me adjusting settings out of pure frustration this issue is still unresolved since day 1  18 months ago id appreciate my interlleave turned off please no engineer  vist will help as we've  had manyyyyyyy before so please turn it off
