Xbox multi player
FIXED- Subscribe to RSS Feed
- Gaming
- Xbox multi player
- « Previous
- Next »
Re: Xbox multi player
04-03-2019 3:39 PM
@JonoH wrote:
We believe it's resolved
Tracing route to aptgm87544.lithium.com [46.19.168.229]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms dsldevice.lan [172.16.0.1]
2 * * * Request timed out.
3 * * * Request timed out.
4 10 ms 10 ms 10 ms 140.hiper04.sheff.dial.plus.net.uk [195.166.143.140]
5 10 ms 9 ms 10 ms 195.99.125.138
6 10 ms 10 ms 10 ms peer1-et-0-0-2.interxion.ukcore.bt.net [62.172.103.124]
7 * * * Request timed out.
8 17 ms 17 ms 17 ms 216.52.199.38
9 16 ms 16 ms 16 ms core1.be3.ams004.pnap.net [216.52.199.50]
10 17 ms 17 ms 17 ms border3.ae1-bbnet1.ams004.pnap.net [95.172.78.38]
11 17 ms 17 ms 17 ms lithiumtechinc-5.edge1.ams004.pnap.net [95.172.78.146]
12 17 ms 16 ms 16 ms aptgm87544.lithium.com [46.19.168.229]
Trace complete.
Erm, is it? 141.hyper..... still timing out here (just this very moment checked). I'm not sure about hop 7 either.
04-03-2019 3:44 PM
I’ve asked my son to check to see if he has any issues and I’ll update you if we do
Thanks again
04-03-2019 4:00 PM
04-03-2019 4:39 PM
I'm more confused than is was before!! It's not hard to confuddle me, but
@DS wrote:
For the sake of my sanity, is this just an XB360 and/or XB1 issue only?No, it can be anything.
Or a small number, as in it's affecting other customers (me included) using other devices too?
yes, it seems to be an issue with the routing rather than with the customers' device.
But now I'm not affected by this
You're not impacted by this issue though. I know this because I know what IP you're using and it's not in the impacted range.
I therefore, reside myself to slowly rock back and forth, mumbling garbage to myself!!
Was it just the 31.***.***.*** or 82.132.***.*** or 80.189.***.*** or 146.198.*.** IP ranges affected - you'll see the recent drop in my connection gave me a dynamic 146.199.***.*** address?
I also surmise, that my issues recently (not the drops or SNR or forum oddities) are caused by factors that I simply can't fathom out ![]()
04-03-2019 9:02 PM - edited 04-03-2019 11:12 PM
--- edited, wrong thread!
04-03-2019 11:08 PM - edited 04-03-2019 11:09 PM
Hi @AvengerUK01
From what I can see you've previously been on a static IP until tonight so it doesn't look like the issues are entirely the same. Are you experiencing the problems as described in the initial few posts of this thread?
07-03-2019 9:41 AM
over a maximum of 30 hops:1 1 ms 1 ms 1 ms dsldevice.lan [172.16.0.1]
12 17 ms 16 ms 16 ms aptgm87544.lithium.com [46.19.168.229]Trace complete.
Hey @DS, those timed out responses don't indicate a problem, just that the host didn't respond to the traceroute. Routers can be configured to ignore or de-prioritise ICMP traffic like traceroutes.
Ex-Plusnet Jobsbody
07-03-2019 10:31 AM
What I was pointing out, was most of the times I've tested, the 3rd hop sometimes is there (141.hyper) with * * x ms, * x x ms or indeed not there at all (as above).
I know hop2 won't be there, plus I wasn't sure if hop 7 should be there either.
I'm not too up on why I sometimes see '141 hyper' then why I don't - same tracert to xyz and it always is either there (but not x x x ms) or not there.
Although I'm too concerned, why would I sometimes see the 3rd hop and sometimes not see a complete 3rd hop when testing to the same destination?
07-03-2019 10:40 AM
Routing changes when it needs to/is forced to. It might indicate an issue, or not! I'll have a closer look though as the 141.hyper thing popped up in a separate conversation internally today.
Ex-Plusnet Jobsbody
07-03-2019 10:45 AM - edited 07-03-2019 10:51 AM
I know going to the BeeBeeCee ain't the one I normally use, here's what I'm saying:
Tracing route to bbc.co.uk [151.101.0.81]
3 * * 11 ms 141.hiper04.sheff.dial.plus.net.uk [195.166.143.141]
4 11 ms 12 ms 11 ms 140.hiper04.sheff.dial.plus.net.uk [195.166.143.140]
5 10 ms 10 ms 11 ms 195.99.125.138
6 10 ms 12 ms 13 ms peer7-et-3-1-2.telehouse.ukcore.bt.net [109.159.252.230]
7 11 ms 11 ms 14 ms peer5-te0-9-0-32.telehouse.ukcore.bt.net [195.99.126.81]
8 10 ms 10 ms 11 ms 151.101.0.81
3 10 ms 11 ms 10 ms 141.hiper04.sheff.dial.plus.net.uk [195.166.143.141]
4 12 ms 11 ms 10 ms 140.hiper04.sheff.dial.plus.net.uk [195.166.143.140]
5 10 ms 10 ms 10 ms 195.99.125.138
6 12 ms 10 ms 14 ms peer7-et-3-1-2.telehouse.ukcore.bt.net [109.159.252.230]
7 11 ms 13 ms 11 ms peer5-te0-9-0-32.telehouse.ukcore.bt.net [195.99.126.81]
8 9 ms 10 ms 10 ms 151.101.0.81
Bonkers! First time I've seen a full hop 3 - someone looking already...?
edit. Might be noting 137.hiper too. I did point this out a while back also ![]()
eg.
3 * 11 ms 10 ms 137.hiper04.sheff.dial.plus.net.uk [195.166.143.137]
4 12 ms 10 ms 12 ms 136.hiper04.sheff.dial.plus.net.uk [195.166.143.136]sometimes
4 12 ms 12 ms 12 ms 136.hiper04.sheff.dial.plus.net.uk [195.166.143.136]
- « Previous
- Next »
