Xbox Live Problems
- Gaming
- Xbox Live Problems
Xbox Live Problems
19-12-2009 3:15 PM
Right, I never had problems connecting to xbox live but now all of a sudden in the last few days I have!!!!
I restarted the router SERVERAL times and get three different error messages at random. The most likely one is not responsing to ICMP responses, that shows up more than any other error. There was another error saying NAT is moderate, which I'm not happy about, it always been open. The third message is cannot connect at all.
So, Plusnet..... whats the problem now?
UPDATE : My brothers xbox works perfectly fine. There been no changes AT ALL on the network and no changes on my xbox. Nothing been changed, so why can't I connect. We both use wireless, we both get 80% to 100% signal strength
6 REPLIES 6
Re: Xbox Live Problems
19-12-2009 4:19 PM
Looks like it seems to be fine now - grrr
06-01-2010 6:34 PM
did you do anything to fix it? iv just posted this issue
i can sign into live but cant find matches and have a red connection when i join a friends. iv also tryed restarting and resetting the router with no joy
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
06-01-2010 6:42 PM
Check this link out from the community library,hope it helps you http://community.plus.net/library/gaming/xbox-360-connection-guide/
If life gives you lemons, make lemonade.
06-01-2010 6:46 PM
um, i know how to connect an ethernet cable to a 360 and into the router!
thanks anyway
thanks anyway
06-01-2010 7:13 PM
Your welcome,head over to xbox.com,theres tons of help to be had there.
06-01-2010 9:00 PM
iv been through all the generic answers with previous connections. im thinking this is something router/plusnet specific
