Project Torque
- Gaming
- Project Torque
Project Torque
05-02-2009 7:00 PM
Please add:
http://project-torque.aeriagames.com/
2 REPLIES 2
Re: Project Torque
05-02-2009 8:06 PM
belive its on the list m8. i did the wireshark capture on it as i requested it. i think mid last year. look at the list of games and its therehttp://community.plus.net/forum/index.php/topic,444.0.html.
all thoe i only did the capture playing on the first server(the most used) not the second one.
gd game thunder ally was all i played but doing more than 15laps with rammers did my head in. plus there is alot of lag's that play it.
might reinstall it see what improvments they have made i will post back if i do and see if you want a thunder ally race but be warned the last torny they ran i came 1st
edit: do a wireshark capture why on the 1st sever to make sure that ariea hasnt changed anything and pn need to update the rule.
Re: Project Torque
09-02-2009 3:10 AM
installed project torque again and ran wireshark and the phoebus sever is still being picked up as Titanium.
if your getting lag when playing this game can i surrgest to make sure your line is on fastpath and not interleved as the sever is in on the west coast of amercia
Tracing route to ip-72-55-177-182.static.privatedns.com [72.55.177.182]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms 10.0.0.1
2 18 ms 17 ms 17 ms lo0-plusnet.pcl-ag03.plus.net [195.166.128.109]
3 18 ms 17 ms 24 ms gi1-6-703.pcl-gw01.plus.net [84.92.0.181]
4 17 ms 17 ms 17 ms te2-2.pte-gw1.plus.net [212.159.0.186]
5 17 ms 17 ms 17 ms te2-4.pte-gw2.plus.net [212.159.1.102]
6 18 ms 17 ms 17 ms linx-gw1.peer1.net [195.66.224.156]
7 109 ms 109 ms 109 ms oc48-so-3-1-0.nyc-telx-dis-1.peer1.net [216.187.
115.225]
8 116 ms 117 ms 116 ms oc192.xe-1-0-0.mtl-bvh-cor-1.peer1.net [216.187.
115.53]
9 117 ms 119 ms 119 ms 10ge.xe-0-0-0.mtl-bvh-cor-2.peer1.net [216.187.1
15.86]
10 109 ms 116 ms 111 ms g9-8.hd-core02.peer1.mtl.iweb.com [216.187.90.13
4]
11 110 ms 110 ms 110 ms ip-72-55-177-182.static.privatedns.com [72.55.17
7.182]
Trace complete.
115.225]
115.53]
15.86]
4]
7.182]
Trace complete.
