Plusnet Routers and Port Forwarding
FRPrice
Re: Plusnet Routers and Port Forwarding
@bobpullen - Thanks for that, it is now working but I don't really know what finally did it! I opened all the ports required and then altered the firewall settings. All good now - thanks for your help.
FRPrice
@Solmark - thanks for the tip, it is now working.
SomersetPeter
Hi, Xbox360 X box live access problems, Plusnet Home Hub
I can't access Xbox Live after resetting the family password, it won't log in. I can log in on the PC, The internet connection tests seem fine
Having  spoken to Microsoft, they mentioned Port forwarding so I contacted Plusnet.
I have gone through the above, however there is a conflict and it asks me to remove a device.
I have under "Game or Application"
Xbox Live
Xbconnect
XboxLive 1 (which is the one I created from the above instructions)
Any ideas gratefully received.
Kind regards
Peter
lindahoskin47
I'm at my wit's end.
I've had ports forwarded for years with no problem. Then sometime in the last month it's just stopped working for no reason that I can see. I've done everything suggested here and elsewhere. I've disabled firewalls, factory reset at least five separate times, used my computer IP in the port forwarding box, and even formatted my entire PC thinking it was a setting on my system.
NOTHING HAS WORKED.
The router makes the connection, then instantly disconnects. Ad nauseum. I've spoken to two different reps who say they aren't trained on port forwarding and that Plusnet "doesn't support" it. It's *expletive* ridiculous. Why did it work for so many years without issue, then?!
13:13:50, 28 Jun.	IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:6000 <-​-​> [46.208.160.48]:6000 -​ -​ -​ [178.120.20.113]:23713 ppp3 NAPT)
13:13:49, 28 Jun.	IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:6000 <-​-​> [46.208.160.48]:6000 -​ -​ -​ [151.231.63.51]:20160 ppp3 NAPT)
13:13:49, 28 Jun.	IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:6000 <-​-​> [46.208.160.48]:6000 -​ -​ -​ [175.195.199.219]:7934 ppp3 NAPT)
13:13:45, 28 Jun.	IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:6000 <-​-​> [46.208.160.48]:6000 -​ -​ -​ [39.37.19.206]:24137 ppp3 NAPT)
13:13:37, 28 Jun.	IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:6000 <-​-​> [46.208.160.48]:6000 -​ -​ -​ [188.191.21.227]:54095 ppp3 NAPT)
13:13:31, 28 Jun.	IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:6000 <-​-​> [46.208.160.48]:6000 -​ -​ -​ [92.37.142.23]:59712 ppp3 NAPT)
13:13:26, 28 Jun.	IN: ACCEPT [54] Connection opened (Port Forwarding: UDP
If nobody can help me with this, I am done.
srangeley
I have been trying to use my work VPN (BT Mobile Xpress) at my parents' house this morning but I have been getting error 12275 - failed to connect to the gateway. It worked the last time I tried it but that's maybe 12 months ago.
They have a 2704N. It works OK from my house on a Hub One (fibre).
Online chat said they couldn't help and pointed me to this forum post.
Is there something I / you need to set please? I haven't previously had to configure anything, it just worked.
Thanks in advance
Steven
Solmark
It is baffling to me why PlusNet don't take these customer issues seriously. Maybe we all have the wrong ISP. I will be looking elsewhere when my contract ends
SammyM
Fixes: 101
Hello @srangeley
Thanks for getting in touch. The error message appears to be specific to your VPN client we would recommend contacting your company's IT help desk.
Having said that while using that connection, have you noticed any drops in connection? or issues with the speed.
 Sammy M - Sheffield Team
srangeley
Hi Sammy,
Thanks, but as I said "It works OK from my house on a Hub One (fibre)."
Therefore it can't be my work laptop or the VPN client, it MUST be specific to either:
1. My parents connection
2. My parents router
Also it worked last year and I haven't changed anything since with their router, so please can you check at your end what has changed.
Steven
Fixes: 1,662
Hi Steven.
If you can PM me their username I'll be happy to look into this further.
I've also asked our products team for advice for example why it should work using a Hub One but not the Hub Zero.
srangeley
Thanks, I have done that.
Steven
Fixes: 1,662
Thanks Steven. I'm not finding any obvious issues.
Mind if I ask the IP/Host Name of the VPN? Also which company is your VPN connecting to?
Finally can you post up a traceroute using your own connection and your parents connection to compare?
srangeley
Thanks for checking.
I'm not sure exactly how to find the IP or host name, I just log in using an e-mail address (which isn't actually a real one!) and code which is obviously generated using my token plus my PIN.
I'm connecting to the Co-op Bank.
Which IP address do you want me to traceroute to?
Steven
Fixes: 1,662
Thanks for this. Looks like it may be due to the IP range (146.159.x.x) your parents account are connecting to. I've tried to force their router to connect to a different range now which should resolve this but it's gone back to the same range.
I'm discussing this further with our products guys and I'll post back again shortly.
srangeley
Thanks Anoush.
I'll check on my own PC which IP address range I'm using at home, I assume I will see this in my router homepage which I can't access using my work laptop!
Incidentally I had the same error trying to log in at home this morning but it worked after I rebooted my hub. It was working OK on Saturday 7th but then I went away on holiday so I turned it off while I was away. Maybe it got a different IP address range assigned when I switched it back on?
Steven
Fixes: 1,662
You were on the 143.159.x.x range until about 9 hours ago, but you're on 51.9.x.x range now.
Looks like it did. Due to the way dynamic IPs are assigned they're very sticky which means you'll likely get the same one, which is happening to your parents connection. Not much we can do to influence that.
I've just discussed with one of my colleagues in our networks team (He roams around here occasionally).
To investigate this further, could you run a traceroute when you're trying to connect to the VPN unsuccessfully? It may also be helpful to see a traceroute when you're not on a VPN, and also when the VPN is working OK.
Cheers!
Anoush
