Pings
- Gaming
- Pings
Pings
22-11-2007 10:56 AM
Just moved from Orange (2mb ip stream) to PN (max adsl up to 8mb Option 2) and have noticed that my pings have increased from the mid 30s to mid 40s/50s on uk servers for games such as DOD source etc.
I was hoping for either a better ping or at least the same when I moved to PN - anybody else noticed this or id it an issue with ax adsl?
Comments appreciated.
Re: Pings
22-11-2007 11:10 AM
We place interleaving on all of our orders as default. This improves stability, but causes approximately 20ms to be added to latency. If you raise a ticket I'll be more than happy to remove it for you.
Re: Pings
22-11-2007 11:17 AM
Thanks for the prompt response.
I would however be interested to hear from other gamers out there first who have had it switched off (interleaving) and what they feel with regards to the stability issue.
Hopefully I will generate some comments here
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
Re: Pings
22-11-2007 11:20 AM
Re: Pings
22-11-2007 1:08 PM
Not sure what stats you were after so:-
DSL Flavour = ADSL over POTS
Reserved Bandwidth (kbit/s) up/down = 448 / 6112
Uptime = 04:01:42
kBytes Tx/Rx = 2357 / 20140
Properties
Output Power (dBm) up/down = 11.5 / 19.0
Attenuation (dB) up/down = 23.0 / 43.0
Noise Margin (dB) up/down = 20.0 / 9.5
Vendor Id (local/remote) = ALCB / TSTC
Statistics
Loss of signal (local/remote) = 0 / 0
Loss of power (local/remote) = 0 / 0
Loss of framing (local/remote) = 0 / 0
Errored Seconds (local/remote) = 109 / 21
Loss of link (remote) = 0
Is that enough?
Still interested to hear from other gamers on the interleaving on/off issue.
Regards
Re: Pings
22-11-2007 1:34 PM
Hopefully someone who knows about these things will tell you what you can expect with interleaving off (I suspect it might mean a small drop in sync speed to keep the line stable but you will see far better pings).
Re: Pings
22-11-2007 1:35 PM
Rockintone - Did you have any issues with stability with Orange?
Re: Pings
22-11-2007 1:39 PM
Re: Pings
22-11-2007 1:40 PM
There's no interleaving on fixed rate services. The number of errored seconds might be cause for concern.
Re: Pings
22-11-2007 7:54 PM
My 2mb line with orange was a stable as a rock. I can only recall i disconection in over 3 years. Then again I do switch my router off when not in use.
I am a bit confused now over the interleaving issue - are you saying that if I switch it off my pings will go up?
Re: Pings
23-11-2007 12:16 AM
I suspect James meant to say that the rate you sync with the exchange can go up once interleaving is removed, rather than ping.
As I understand it ping times will reduce once interleaving is removed. I don't know how much by, but at least 10ms-20ms I would have thought.
Re: Pings
23-11-2007 7:01 AM
but it can cause malformed packets, because there is no error correction. and they need resending which slows things down if you have a noisy line.
Realy not worth the hassel in my opinion. I'm only 300m from my exhange and found that Fastpath caused about 4 line dissconnections a day that required a router reboot!
Re: Pings
23-11-2007 9:18 AM
Quote from: 7th_star I suspect James meant to say that the rate you sync with the exchange can go up once interleaving is removed, rather than ping.
Yup, thanks. I've amended my earlier post.
Re: Pings
23-11-2007 10:02 PM
Re: Pings
24-11-2007 8:25 PM
my username is lfcshanks
