PS3 firmware update
- Gaming
- PS3 firmware update
PS3 firmware update
02-12-2008 11:51 PM
About the only change I've noticed in the update is that the BBC iPlayer now works.
Well it displays a blocky picture
Can't believe there isn't access to the high quality stream.
Anyone else tried it yet?
3 REPLIES 3
Re: PS3 firmware update
03-12-2008 11:10 AM
Not yet, shame about the high quality streams. Have you tried www.ps3iplayer.com?
03-12-2008 11:12 AM
Not yet..
scurries off to switch the PS3 on....
03-12-2008 8:19 PM
I've just had a play with it and it seems to work ok. Not the best picture in the world but watchable.
I think that this update is probably only the first step towards full iPlayer compatibility. Hopefully they'll improve the picture quality and then do a full media launch like they did for the Wii. I reckon that Sony would want to put a shortcut on the XMB as well.
I've been using www.ps3iplayer.com for some time. The problem is that it's never been properly supported so was often unavailable. A BBC supported service is definitely a step in the right direction.
Bob
Bob
